Shuttle Adjustments
  • Shuttle Adjustments
    What are your thought on lowering the shuttle closer to the table to say 1 1/4 from 7/8? The reason for this would be to allow the pins to sit lower in the bins. The second stack would hit the "foot" more solid and not shoot over to the side (mostly 6pin). The reason for this is the shuttle got bent up from a table jam. They do run much better with the pin lower in the bin. What are your thoughts on this? Just wondering.
    Re: Shuttle Adjustments
    I just lower the whole bin and shuttle assy. this stops double shuttling and the pins slide easier into the cups. this is good to do if you have wood decks that have been sanded a lot. this brings the bin and shuttle back in coralation with the table.
      Also, why do some shuttles have a greater gap at the back on the 10 pin side? The shuttle is slanted. The black spring moved over will not compensate for the twist. What is causing this?
        The shaft in the front of the shuttle twists over the years. Stupid design, the shuttle actuator is on the 7 pin side & no support at all on the 10 pin side.Someday,that shaft will break, & when a new shaft is installed,the back of the shuttle will be straight once again.
          If you want your shuttle to track evenly on both sides try this little trick. I've been doing this for a number of years now and its worked quite well. First, take a couple of 1 1/2 wide metal strips about 6" or so and bend them at 1" so you have a right angle. Empty the bin. Take the spring that pulls the shuttle forward off. Next get under the machine on the 10 pin side. Take the 10 pin side drive arm off the shaft. Remove the key from the shaft, and replace the arm on the shaft and shuttle. DO NOT tighten the arm to the shaft yet. Take the two pieces of metal and using vise grips clamp them to the top of the bin so they hang down below the shuttle and are supported by the back of the bin. Take a light spring and hook it to the shuttle so as to draw it up against the two pieces of metal hanging down. as the shuttle moves forward, it now squares itself on the two pieces of metal. You will also notice the 10 pin side arm move on the shaft too. Once the shuttle is against the metal securely then go ahead and tighten down the clamp stud on the arm. I used a stover lock nut to make sure that it will not come loose. Remove the light spring, metal and reconnect the regular shuttle spring. Now when the shuttle goes forward, it will go straight.
          AMF DOCTOR
          The doctor makes house calls.
          AMF DOCTOR
            Could you post a pic of that.....
            Thanks
            Peanut
              The shuttle's two front arms can be perfectly parallel and your shuttle may still show more on one side than the other. This can be because the shuttle "rack" is not square!
              To check this, empty the bin and look at the relationship between the shuttle linear (front-to-back) tubes and the bin stringers. Adjust the spring to get them in line. If they do not line up, then the problem is in the front arms or the front mounting brackets. To correct this, disconnect the spring, lower the table, disconnect shuttle at the rear rods, lower the rear of the shuttle rack and force it over in the direction needed to make them line up. Reconnect the rods and observe the gap at both sides. If it is still greater at one end tahn the other, then the rack is out of square and needs to be corrected.
              To correct: with the table still down a bit and the bin empty, hold a block of wood between the bin rear channel and the shuttle rear tube at the side where the gap is less. While holding the block firmly, give the other side a shove forward. Repeat until the both sides match.
              Lowering the rear of the rack? OK, but only if (after years if sanding) the machine is still at the original height (19" off the deck) AND the table has been lowered.
                Bowlequip has it the way I do it, although I like the sounds of AMFDoctor's bit, so I'm going to try that next time i need to. Thanks
                the best tech knows the correct moderation needed when swinging a 2lb lump hammer...... OUCH!
