82/70 4-5-6 row of bin
  • 82/70 4-5-6 row of bin
    Can anyone explain why the pin guides on this row are at a 45 degree angle? All other bins the angle is at 30 degrees. Even if there is a good reason, why does the top stick up above the bin wall? This allows the neck of a pin to lay on a step if it bounces up real hard.
    Re: 82/70 4-5-6 row of bin
    Yes the 4 and 6 pins can be a pain. The 4 will lay over and block the 8 while the 6 will lay over and block the 9. Check out this thread. Masternuts batwing mod . Try applying that mod and the second row of 4 5 6 pins in the bin will lay straight. I have used this mod myself on trouble machines and it does make a big difference because the 2nd row cannot move.
    Wang
