Sweep Creep at 270*
  • Sweep Creep at 270*
    Hi there guys,
    I have a lane at my place where when the sweep reaches 270 it wants to creep backwards ever so slightly, most of the time it doesnt create a problem but from time to time the sweep wont return to zero after the table goes up to 355 after respot. I changed al the p.c. boards 1 thru 5 no difference and swapped te chassis with the lane next to it no diff. Any ideas would be much appreciated hey fellas as this is one of the MANY woes i have inherited hahaha oh well ya get that.
    Cheers Brett
    Re: Sweep Creep at 270*
    Most probably a motor coasting problem. Try swapping the sweep and table motors round. Sometime this can get you out of a tight spot. But doesn't solve the underlying problem. Checkpins in chassis plug's for bad or burnt connections. If you find any always best to change the lot and fit new socket at same time.
    Let us know how you get on.
      sounds like the sweep motor to me,the gears could be slipping or the bolts attatching the gearbox to the machine could be loose causing sweep creep.
        Check the SA microswitch and cam lever adjustment. A bad microswitch will cause the sweep to stop inconsistently.
        Wang
          I'm with Wangj on this one. Everytime I've had that prob. it's 9 out of 10 times that is the prob.
            Agreed, SA cam switch, weak cam lever spring for the switch, or possibly a sloppy bearing next to the crank arm, loose crank arm on the shaft,loose gearbox components (old gearbox)sometimes removing some internal gearbox shims can help.
            John
            804-240-4982
              Im with John on this, but the shims are more noticeable if it were the table motor with the problem, running backwards at the top. Remove the shims at the 4 x 3/8 bolts side, not the ring gear side.
              the best tech knows the correct moderation needed when swinging a 2lb lump hammer...... OUCH!
                I go with John on it, loose or sloppy crank arm and or bearings. also could be the splines on the drive shaft are worn.
                  nationals with worn carbon brushes. and in particular Franklin Electric combo motors will do as described. particularly if sweep over runs 270 and is up in the air, motor cant hold it, and so it coasts back down. . .backward.
                  Also the mechanical slop of what laneman and john said could also be. if the sweep runs back enough to allow the SA lever to go back in, the chassis will assume the sweep is at 0.
                    I'll go with the brushes. Every time I get that I change brushes, clears right up
                    Without Mechanics Where Would We Be?
                      If swapping the motors doesnt stop this check the c-1 plug for burnt pins.I had a couple of burnt pins in the c-1 plug 1 time and caused this problem after replacing the burnt pins problem cleared up
                        SA adjustment, cam lever spring, also check TB adjustment.
                          Does the motor coast at any other position (namely 0 and 66)?
                          With the machine at zero, press the sweep run switch quickly to let the sweep down about half way (to say 30 degrees). That should expose any costing too.
                          I interpreted from your post that the sweep does actually reach the proper 270 position, but *then* creeps backwards. Is my interpretation correct, or is the sweep actually stopping early?
                          Checking sweep cams is a good idea if the stopping position is wrong. But you seem to be suggesting that the stopping position is right, which implies cams are right but motor is slack (either gearbox or brushes).
                          Andrew.
                            Andrew,
                            Ya spot on mate, the sweep reaches 270 perfectly but after stopping creeps back, also it doesnt creep at 66 or 0 only 270.
                            BTW Andrew some time soon ill be buying another copy of parts tracker off you, i was the one who got Neil from windsor to buy it from you but i have left now and gone to Fairfield so i will have to get it again.
                            Cheers Brett
                              Hi Pin Head, your at Fairfield, thats where I started in the industry, on my 17th birthday, 1969.
                              I worked there again in the late 80's, is everything still painted Blue, every Centre I work in I paint the Machines Blue and the walls and the floors.
                              Good Luck there mate.
                              Frank.
                              always doing my best.
