Franklin Motors
  • Franklin Motors
    Does anyone have a part # for Franklin frontend gearbox motor housing plate that attaches the motor to the gearbox?
    Re: Franklin Motors
    You should be able to get it of Amfs website I'm am getting the new gear boxes so the number is not the same but go to their website and look under moter manuals and the will have an exploded view of the gearbox with the number.
      Re: Franklin Motors
      the part is listed as an a'ss with the rotor and bearing ect.
      50hz 090 004 525
      60hz 090 004 526
        Re: Franklin Motors
        50hz 090 004 525
        60hz 090 004 526
