Rear Roller Repair Kit
  • Rear Roller Repair Kit
    Hey there again my buddies,
    I was wondering what everyones opinion was of the AMF Rear roller rep kit? I think they are great but i have a sh1t load mates who tell me they suck big time??? So far i have used about 10 of them and never had ANY probs as long as they are installed correctly.
    How do all you out there in the wide world of bowling feel about these????
    Cheers Brett
    Re: Rear Roller Repair Kit
    Pin Head are you refering to the half moon to hold the roller bearing in. If so I used the old worn one as a template, grind off the projected area and drill the holes for the new one and bolt in.
    Frank
    always doing my best.
      Not to hijack a thread, but is there a repair kit to fix a shaft that has been cut off? Could it be used on an 82-30 short shaft roller, making it as long as an 82-70 roller?
      Gene Simmons for president!!!
        Frank
        <font size="2" face="Verdana, Helvetica, sans-serif">When you do mount one of those on.... rotate the new support retainer forward about 1/2 a hole from the original location.
        Because of the way the belt tension is on a '70, most of those retainers blow out the bottom. Rotating the new retainer forward puts more support on the roller bearing.
        -- Larry
          <font size="2" face="Verdana, Helvetica, sans-serif">I recall someone offered a repair kit at one time, but it involves taking the entire end off (by carefully grinding the weld off) and welding the new one on.
          Unless rear rollers have jumped in price, I don't think it'd be cost effective.
          -- Larry
            I used about 5 of these and they are great! It´s very important to have a good solid square base. Take good care with grinding! Once you have installed them you never have to fear broken rear rollers.
              Ya see prob here in Australia is repair kit is around the $100 mark where as a new rear roller is approx $800.
              Also Willey what i was referring to was not the support that mounts to the kick back back the actual rear roller shaft repair kit.
              <font size="2" face="Verdana, Helvetica, sans-serif">As far as im aware yes you can what you have to do with the kit cut down the shaft so there is approx 1" of shaft stub left apply loc-tite to the stub and slide the new shaft over the stub and drill 2 holes with the bit provided perpendicular to each other and insert roll pins also provided. I find them to be a fantastic cheaper alternative to either sending them away or buying a new roller, i just wanted to know if others have used them what they thought of them????
                <font size="2" face="Verdana, Helvetica, sans-serif">What i forgot to add was there must be i think its approx 3/4" of shaft stub left 1" is better but if it snaps off flush with the end of the roller then its no good.
                  $800 for a rear roller,,whoa
                  Her in the uk they are about £70.00, not sure what that convers to Aus$.
                  I reakon that I could sell you one (at the cost I buy it)on EBAY and ship it to you cheaper than that.
                  In fact if that worked out cheaper I may know a supplier who would do that.
                    What would you guys think of a rear roller that had a full lenth shaft through it that was threaded. This way if you have shaft get cut off you could just replace the through shaft in 5 of 10 minutes. I've been working on somthing close to the before mentioned please let me know what you think.
                      Saturday, June 25, 2005
                      70 British Pound = 166.030 Australian Dollar
                      70 Australian Dollar (AUD) = 29.51266 British Pound (GBP)
                      Median price = 2.36967 / 2.37186 (bid/ask)
                      Estimated price based on daily US dollar rates.
                        Thanks for the info guys. BTW, here in the states a new roller is around $85.
                        LaFarge, next time we see each other, I would like some more info.
                          <font size="2" face="Verdana, Helvetica, sans-serif">Lafarge,
                          Your idea sounds like a winner.
                          Keep in mind that you would need an odd and even roller because the threads should be counterclockwise for the even machine and clockwise for an odd.
                          Other than that (for a universal roller), I would think that you would need some type of setscrew, jam nut or some other type of retainer to keep the shaft from unscrewing.
                          Triac
                            When we had the 30's, B.C.A. gave us new pieces of shaft and we had to torch out the old shaft and weld in the new section. We put alignment marks on the roller and cut the body of the roller off about three inches from the end. Burn out the old shaft and weld in the new piece. The hard part was getting the roller welded together straight. I used hacksaw blades for the spacing and aligned the marks.(spacing was needed or the roller would be shorter) Then put a few tacs on the body of the roller and see if the roller was running true on it's rearings. You could "adjust" the roller body with a bowling pin. Once you got it true, just weld and grind. I did about six of these repairs and told them it was a waste of labor to do any more.
                            Rep. Rob Bishop (R-UT)
                              Had a look how much it would cost to ship £214.00 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
