Need part number
  • Need part number
    Good afternoon all.
    After searching painstakingly thru several parts books, I am unable to find this. I am looking for the connecting bracket that connects the 2 PBL ring weldments together underneath it. The bracket goes onto 2 screws of each ring weld (4 total). The bracket also acts at a filler to keep pin heads from getting wedged into the weldments. Does anybody know what this part number is? Any help would be greatly appreciated.
    Re: Need part number
    Is the ball door metal or plastic?
      I use them on both, since I have both the metal and the urethane door rings.
        I’m assuming you are talking about the bracket that has a bent “hotdog” welded on top.
        Rail Weldment (aka hotdog bracket) 070-008-207
        Spacers 070-008-212
        I too use this bracket on the metal and urethane assy’s. After all, why would AMF put studs on the urethanes if not to be bolted up?
        Triac
          Triac thats exactly the one.
          Thank you very much!!!
          Bob
