I am installing expanders and I have come across something new for me.
I have 70's that were put in by Stahl's with external motor start relays and National Motors.
What needs to be changed to get these motors to reverse instead of just hum. I know that there is a wiring modification and I need some input.
Thanks in advance !! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
If they are Cybernetics, then they would have come with instructions for fixing sweep reverse, otherwise the same instructions are available on their website (http://www.cybernetic.com.au/Bowling...s/Ssc70rev.pdf).
However, did you have sweep reverse *before* you added expanders, or have you been living without sweep reverse ever since Stahls installed the start switches? It may be related instead to the reverser relay wiring for the expander, and not the actual motor or start switch wiring.
About a year ago we installed expander boards on twelve mach's. with the newer Omega-Tek boards. We had to remove them because of numerous problems. The false strikes were the worst of the problems. That would wipe out a few cells and some studs every time. We replaced all the micro sw's thinking the old switches might be bad. Everything in the Accu-Score system was changed out. The newer cameras didn't help either. We have Nationals with SSSS and there weren't any problems with reversing the sweep when the EX boards were in.
Rep. Rob Bishop (R-UT)
Red wire from TSA2 to #2 on the relay
An added wire from #1 on the relay to TSA2
An added wire from #5 on the relay to TSA3
That was how stahls wired the machine from the start. However since you added expanders for short cycles. Make sure the following modification is added to the sweep wiring.
Add a wire from #5 on the relay to TSE2. Hopefully that will solve your problem. If you need more assitance call Jamie at Stahls. 952-432-2231.
