Shuttle ??
  • Shuttle ??
    had a problem with the back of shuttle wobling a little bit when it sits a rack of pins on about 3 lanes.found rod assemly bent a little also wondering how tight spring should be? #070-006-306
    Re: Shuttle ??
    <font size="2" face="Verdana, Helvetica, sans-serif">The shuttle connecting rod should be tight. There is no adjustment for the spring.
    If the shuttle is wobbly then I would check the clamp stud nuts on the shuttle arms. (070-006-429) The nuts should be quite tight.
      Re: Shuttle ??
      If you have a shuttle that sways side to side then I would check the rod that runs from the ten to the seven side. it sits right in front of the head pin. That rod sometimes gets spiral cracks in it and it will actualy twist a little causing the before mentiond problem. It usually starts in one of the keys. That will put the arms out of alighnment. Clutch is right on about the shuttle rod in being that it has to be as tight as possible. That is if you want a good running shuttle to last.
        Re: Shuttle ??
        THANKS FOR REPLIES CHECKED ALL BOLTS GOOD &amp;TIGHT THERE HAS TO BE ADJUSTMENT ON SPRING SOME MACH. ARE 8 IN. SOME 7 3/4. WILL GO &amp; CHECK KEY WAYS THIS MORNING.SHUTTLE ALSO HITS TABLE FRAME A LITTLE BET IN FRONT OF 7&amp;10 PINSIDE
          Re: Shuttle ??
          thanks clutch &amp; lafarge checked key ways all ok took shuttle out had one bent tube a little bet. so had it out i put bin staps on all but head pin seems to have cut down wobbly quiet of bet
            Re: Shuttle ??
            Older 70's had springs on the shuttle connecting rod that were made of flat stock spring wire. These would weaken very quickly and create back &amp; forth bouncing.
            The newer springs are made of round stock and have lasted for over 15 years (still OK) since I changed them all.
            Ball Returns Shorted Out?
            Trip rocker arm
            Lower ball cushion board
            Backend motor plug
            82/70 combi motors
