21 pins
  • 21 pins
    How many of you run AMF machines with 21 pins?
    since 4 years it still works fine in our center. It will compensate the missing pin idleing in the pit so people don't have to wait after a double strike.
    For so far I didn't see 3 pins in bin 1 causing pinjams.
    what's your experience?
    Re: 21 pins
    Yep, 21, no probs
    If Wile E coyote has enough money to by all that Acme crap why doesnt he buy his dinner?
      Re: 21 pins
      We have ran 21 pins for about 6 years....helps with eliminating the occasional head pin shuttling and falling thur table......
      Peanut
        Re: 21 pins
        We do it here. The only prob is at night with the kids they don't check which lane the pin come out and just throughs it into any machine causeing me headaches in the morning!!!
          Re: 21 pins
          I thought it was a standard practise. I've been doing it for years.
          Like Marc said, You only have to watch where you throw the loose pins behind the machines. But then you have to or should be doing that no matter how many pins you have in.
            Re: 21 pins
            Always have and always will run 21.
              Re: 21 pins
              The industry standard.
              I did switch back to 20 a couple years ago because of some problem....I forget what it was......bad memory.
                Re: 21 pins
                I have always run 20. I have no complaints.
                  Re: 21 pins
                  We've always ran 20.
                  We'd have trouble trying to get the people "higher up" to pay for 3 extra boxes.... Heck, they haven't given us any new pins for over 2 years!
                    Re: 21 pins
                    always used 21.
                      Re: 21 pins
                      Yep im in the 21 club as well, helps speed up double miss or double strike cycles when you get a pin idling in the pit.
                      I'm Brian and so is my wife.......
                      http://www.badassbowling.com
                        Re: 21 pins
                        21-23 here..ya never know. by closing time on Sat. I might be down to 15..my Lab runs down & gets the AWOL pins out of the gutter( big people pleaser :p ) & the office usually has a box or two on the floor by midnight
                        HEY...have you ever been too busy to deal with a swinging dizzy ( from 3 to 2)...& put 23-24 pins in so the dizzy 'rests' at the 2 or 4 pin spot ? [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
                          Re: 21 pins
                          <font size="2" face="Verdana, Helvetica, sans-serif">Sounds too familiar. I've wanted to run 21 since I started there, never happened. Granted for us it's 7 cases extra (64 lanes) but still, it wouldn't break them and would be nice.
                            Re: 21 pins
                            21 for tournaments and scratch leagues.
                              Re: 21 pins
                              Our distributors/wheels run way too fast, and we eliminated pins idling at the roller and at the plow. No problems with excessive wait time... even running 17-18 pins doesn't cause much slowdown.
                              21 pins can be done, but it seems to cause more pileups at the head pin bin on our machines than just running 20.
