Distributor Manual
    Re: Distributor Manual
    But it will never have as many parts, my first detector started out in a 5 gallon bucket with no diagram to work with. Took a few months but it did get put together and is still on a machine to this day.
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
      <font size="2" face="Verdana, Helvetica, sans-serif">To tell you the truth, detectors dont have very many parts.
      My 42 page manual is in my head.
        I am looking at it as we speak as it needs to be in mine as well.
        Drill
        David Bolt
        Champaign, IL
        USBC Silver Coach
        IBPSIA BOD
        IBPSIA Advanced
        Technical Certified
        Pro Shops
          Only took 40 years to get the pinion gear lubrication right. lol
            does anyone know of a similar manual for the 82-70 distributor... I'm trying to rebuild pretty much all of them in my 8 lane center, and I really don't know where to start.
            Marc
              It is the same.
                This thing says to oil your clutch (frictioin disc), if I am not mistaken. I was always taught to not oil a clutch and am having a hard time see how this could not hurt the operation of a clutch.
                Do you guys put a drop of oil on your friction disc?
                  Well pat, since one of the benefits of being a bowl-techer is sharing ideas, I'll pass on something I've been testing reqarding clutches. Now- keep in mind this is the first post for machine modifications I've made.
                  But to first answer your question, in my opionion - there is no reason to lube your clutch. Only causes hesitations at critical areas when needed.
                  Now for the mod- I've been testing over the past year something that seems to be working for me. On the Clutch Plate, I glued a clear piece of plastic over the hole in the plate where it contacts the stop blade. This keeps any grease seeping in during your monthly lubes. But I didn't stop there, I also glued the friction disc to the clutch plate. This was also an attempt to control the amount of oil/grease that may seep into the clutch, but had an additional benefit. I can cut back on the spring pressure to 1/2 turn (makes sense really - only 1/2 as many pressure points working on the clutch). Scuf up the friction disc to add "grab-ability" on the disc.
                  Just did my summer/annual maintenance on the test lane today, clutch problems are zero- but still under test evaluation. I have two other lanes under evaluation also, but not with the plastic guard in-place. There is a DOWN SIDE, for those of us that hate noises not normally associated with the 82/70: If the drive shaft is bent (at all) the clutch makes a "chatter" noise. This happens on both my other test lanes, but never on the original test lane.
                  I hope I have made this clear enough for other B/T members to "see". If it helps you, I would feel gradified to help someone else - like ya'll have helped me in the past. If not, sorry for such a long post (for me).
                  Cheers All,
                  Steve [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                    Cheers All,
                    <font size="2" face="Verdana, Helvetica, sans-serif">Glueing the disc to the plate is a bad idea.
                    The worm allow the clutch to slip.
                    It is no wonder you only need 1/2 turn.
                      I use Plastic E from AMF to lube the pinion gear. And I do everything Gman does. I rebuild them once a month, and have no problems with my clutchs. They are stock, no modifications done.
                      Mike
                      Mike
