leak under pin wheel
  • leak under pin wheel
    my lane 8 machine is leaking some sort of oil or grease under the pin wheel... does anyone know what it might be, and how I would fix it??
    Marc
    Re: leak under pin wheel
    BE gearbox oil.
      BE Gearbox or ring tube oil.
      Mike
      Mike
        There you go. Those are the only 2 possible sorces. If you over filled the ring oiler you will have this. Back end gear box leaking is the other possible sorce. Easy enough to find out. Look in the tray under the back end motor. Is it full of oil ?
          The pinwheel is coated with a tar like noise dampening material. If it was cleaned with some sort of solvent cleaner, it could cause it to soften and drip onto the floor.
          Ball Returns Shorted Out?
          Trip rocker arm
          Lower ball cushion board
          Backend motor plug
          82/70 combi motors
