Handheld unit on xli
  • Drillmn300
    Re: Handheld unit on xli
    Thanks, I am thinking of a few different lengths as I can be on top of the machine and cycle,zero the table or sweep and get still see the whole machine.
    thanks John
    Drill
  • John Isbell
    Matt says it has to be a crossover cable.
  • John Isbell
    Don't know for sure, probably won't hurt to try both. I'll call Matt and find out.
    I made the same comment, the reason for the short cable is for CE compliance, the CE folks don't want the cable to get stuck in the machine.
    I voted for an IR version.
    I suggested a extended kit to put the port on the mask frame, could be done in house faily simply.
    Let you know!
    John
  • Drillmn300
    started a topic Handheld unit on xli
    Hey John, do you know if the hand held
    RJ45 cable is hub to hub or hub to computer? I need a longer cable than the one provided, I can look at it when I get over there but was going to make one up in advance.
    thanks
    Drill
