No cycle
  • No cycle
    Hey guys I need some help on this one. I've narrowed the problem down to the chassis by switching with another known good one. It will switch the ball light but no cycle. I have an SS chassis with MK-70 boards. Checked the c1 and c2a plugs both good bad pins replaced on each side. Swaped MK-70 boards with known good ones. Could this be a posible bad T1 transformer? I've also taken the gray wire off the T2 transformer. the sweep will run if you manualy use the contacts, but it won't run with the cam switches. This condition is the same with the table. Any help will be much aprciated! Thanks in Advanced!
    Re: No cycle
    By any chance are the table and sweep switches turned off in the BE control box?
      Re: No cycle
      If ya havent already, check your chassis relays. A bad "M" relay did this to me once. If ya havent swap that out with a known good one. And also as clutch plate mentioned check the switches in the rear control box
        Re: No cycle
        I agree with Rep (change the M relay), but also check Fuse #3 (if you have one).
        If changing the M relay and fuse doesn't help, then check wiring for Fuse/CB #3, M relay (pins 9 and 11), C2A-35, C2A-11, and C2A-12 and its earth connection (spade terminal).
        Cheers,
        Andrew.
          Re: No cycle
          Relays have caused that problem here a few times with our MP's
            Re: No cycle
            I've tried swaping the M relay with a brand new one, but you guys know as well as I do not all brand new parts work. I will swap that relay with the lane next to it. Yes the B/E switches are on and tested good for continuity. Keep those ideas rollin' in they are all great ideas.
              Re: No cycle
              If the pit runs but you have no cycle, definetly look into the fuses and fuse holders for any problems. Perhaps a wire off on the M relay socket also?
                Re: No cycle
                Boy I tell ya I otta kick myself in the but, turned out to be the F3 fuse. I only did a visual inspection. Should have put my multimeter accross it to make sure. Thanks for all you help guys.
                  Re: No cycle
                  IS THE MACHINE ON PRACTICE?
