need more ideas
  • need more ideas
    I have read earlier posts about swinging dizzys especially from the 3 to 2. i have a few that i cant stop from happening. here is what ive already done: new housing weldment, new drive shaft & u-joint, new clutch (entire), new springs, new safety link, dizzy is level, o-pan does not touch pinwheel, and clutch spring is set 1 notch above minnimum pressure needed. this is very frustrating. any ideas? thanks for any replies!
    Re: need more ideas
    Just a couple off the top of my head...
    Stretch a pair of kicker springs on to the coils of the back springs to give 'em a little extra pull that will dampen out the sway.
    Make sure that the driveshaft isn't bottoming out in the distributor drive and making it bounce.
      Re: need more ideas
      Thank you G Man. no bottoming out in shaft. have extra springs on already and helps, but what can ultimately cause this? im lost!!!!!!??????
        Re: need more ideas
        could a short belt cause this? maybe? bearings in the casting? i hate dizzys! mine distribute fine...IF THEY DONT SWAY!!!!! AAAAARRRRGGGGGGGG!!!!!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
          Re: need more ideas
          Does your distributor want to go one way or the other without springs and a driveshaft? Just a naked dizzy attached to nothing... does it gravitate in one direction?
            Re: need more ideas
            Hi monkey... it will move JUST a slight bit to the left (from back) but not enough to make a difference. i mean maybe half an inch. thanks!
            [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
              Re: need more ideas
              Could always cheat, I post this a lot on here. Take a pit drive belt tensioner spring and hook it to the lateral drive arm on the dist. and the pin on the o-pan. This stopped the wobble from the 3 to the 2 on a few lanes I never got to get into as of yet. It is a rig and ya should find out the real cause, but if it's causing you pin jams it should help
                Re: need more ideas
                I Knew a guy in Colorado that tried this and it worked but you have to be careful because your safty link will be useless. He took and made a bracket to put a cam follower on the inside of the directional side of the cam that way it would trap the cam so it couldn't bounce from the 2 to the 3 and it worked but again you had to be carfull because if your dizzy gets hit or jared in any way it could cause the inside cam follower to break though the cam.
                  Re: need more ideas
                  posted by lafarge
                  __________________________________________________ _________
                  Can't wait to try that!!! Hehe
                  [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                    Re: need more ideas
                    Mike I never said I tried it but sound like it may work. You just have to watch your chacersnot being to rough with the dizzies.
                      Re: need more ideas
                      Welcome back lafarge!!!!!
                      Gene Simmons for president!!!
                        Re: need more ideas
                        I would hazard a guess at the needle bearing needs replaced in the dizzy shaft housing. Have a dizzy which has a bad swing but have used the spring method to smooth out the operation of it until I get round to changing out the bearings.
                        Also check the plate that the safety link spring attaches onto. If the the plate is bent toward the back of the machine you will loose spring tension, so all you need to do is turn the plate around, and you will re-gain some spring tension!
                          Re: need more ideas
                          Not enough room between BE motor and distributor at the #3 pin position.
                          Check if the BE motor is not tilting to-wards the distributor.
                          So it goes.
                            Re: need more ideas
                            <font size="2" face="Verdana, Helvetica, sans-serif">Good idea I had a westinghouse motor once that the housing of the motor was just a bit bigger than my nationals. The housing was hitting the drive shaft causing it to bounce and cuase all sorts of jams. To check just swing your dizzy from side to side and check the space between the motor and drive line.
                              Re: need more ideas
                              check that the support bolt going thro the post is tight. also check that safety link is tight and screwed in as far as possible into the eyebolt.i presume that the pinion and sleeve are ok and not binding.as suggested above put extra tension on the lateral spring to try to stabilise the swing.
                              interested to hear what works.as Alastair says check the link is not bent to the rear also.
                              good luck.
                              maister
