schematic
  • schematic
    does anyone have the schematic that shows how to wire a seimens contactor to table and sweep? weve lost ours. thanks!
    Re: schematic
    Contactor
    Wiring Instructions: For Installation of New Contactor in place of the Old System
    Follow these instructions as though you are looking toward the front of the machine. Old contacts facing away from you.
    DO NOT REMOVE ALL THE WIRES AT ONE TIME! Remove the old contactor from the chassis with the wire connected, then remove and connect the wires one terminal at a time. Contactor is to be attached to chassis with terminal 14 (N.O.) and 13 (N.O.) towards front of chassis.
    New Wire Position Terminal #13 Front Right = Wires from Top Front Right of Old Contactor
    New Wire Position Terminal #21 Front Center Right = Wires from Lower Front Right of Old Contactor
    New Wire Position Terminal #31 Rear Center Right = Wires from Lower Rear Right of Old Contactor
    New Wire Position Terminal #43 Rear Right = Wires from Top Rear Right of Old Contactor
    New Wire Position Terminal #14 Front Left = Wires from Top Front Left of Old Contactor
    New Wire Position Terminal #22 Front Center Left = Wires from Lower Front Left of Old Contactor
    New Wire Position Terminal #32 Rear Center Left = Wires from Lower Rear Left of Old Contactor
    New Wire Position Terminal #44 Rear Left = Wires from Top Rear Left of Old Contactor
    New Wire Position Terminal #A-1 (Under terminal #13) = Orange wire from old contactor for sweep contactor. Gray wire from old contactor for table.
    New Wire Position Terminal #A-2 (Under terminal #44) = Yellow wire from old contactor for sweep contactor. White wire from old contactor for table.
    Jumper wires should be moved with the wires they are connected to, if they are not, the wiring sequence is as follows:
    Terminal #13 & 43 JUMPER WIRE
    Terminal #14 & 22 JUMPER WIRE
    Terminal #14 & 44 JUMPER WIRE
    (This sequence is the same for either table or sweep contactors)
      Re: schematic
      Thank you Felix!
        Re: schematic
        Bent Wrench; Your Welcome I Think [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] I copied these directions but I do not think mine are wired this way [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] Will check for another set of directions........
          Re: schematic
          ok thanks. im in no hurry. just want to get them back. the mechanic that just left replaced all harnesses with ones he built. the only problem is... EVERY WIRE IS RED! [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] including every c-1 wire in the chassis. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
            Re: schematic
            1. Top LH Front = Term #13
            2. Top LH Rear = Term #43
            3. Top RH Rear = Term #44
            4. Top RH Front = Term #14
            5. Bottom LH Front = Term #21
            6. Bottom LH Rear = Term #31
            7. Bottom RH Rear = Term #32
            8. Bottom RH Front = Term #22
            N.C = Lower
            N.O. = Upper
            Sweep = 3 wires - A1
            Sweep 1 wire - A2
            Table 2 wires - A1
            Table 1 wire - A2
              Re: schematic
              <a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank"><a href="http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000" target="_blank">http://www.bowltech.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=001895#000000</a></a></a></a></a></a></a></a></a>
              Check out that link. Bout 2/3 of the way down I posted a schematic sent to me by triac. It shows the color of the wire and were they go to on a set of enclosed contactors like semiens/ge(vantage). Download the pic and print it out as it is very helpful.
              Wang
                Re: schematic
                <font size="2" face="Verdana, Helvetica, sans-serif">I had a machine once that had been repaired by an electrician after a C-1 meltdown. He used all red wire in the C-1 cable. Plus.... he put butt connectors (wrapped in shrink tubing) on every wire a couple inches from the block (thinking that would make replacing blocks easier)..... AND on the C-2As!!!
                And that's when I learned to go build my own C-1s.
                -- Larry
