No Pindication
  • No Pindication
    Hi guys,
    I have a problem with one of my chassis',
    what the problem is , is that i have got not pindication, well i do for about 2 mins, after about 2 mins i lose all lights as in no 1st or 2nd ball light no X light . I tried all 5 boards from a known good working chassis, i changed the cp2 in the chassis no difference. The PM plug connections appear to be tight and in good order.
    Any help would be muchly appreciated.
    Cheers Brett
    Re: No Pindication
    It was CB 4 (fuse) in my MP Chassis Thursday.
      Re: No Pindication
      Is this a S/S chassis? The klixon may be going bad if so....
        Re: No Pindication
        If it's solid state than it's for sure the clixon! But check for short cuts first. Most of the time a nut comes loos and get's in between the side of the chassis and a board. Shake the chassis up side down and see what drops out. Otherwise your masking unit makes a short cut to ground.
          Re: No Pindication
          Bag the 5 boards and go Omega Tek.
            Re: No Pindication
            King has spoken all royal deciples may bow down now.
              Re: No Pindication
              I am actually decipleless now I believe.
                Re: No Pindication
                Take bottom cover of chassis off and you will see a silver heat sink in one of the corners. Make sure a nut didnt ground out something in there. Look hard because it may be stuck inside.
                  Re: No Pindication
                  <font size="2" face="Verdana, Helvetica, sans-serif">Nah, I'll always be your deciple King... As said check out the heat sink under T1, make sure nothing is in there causing the klixon to blow. Sometimes a nut or whatever will get in there causing this, good luck
                    Re: No Pindication
                    Thank you.
                      Re: No Pindication
                      Thank you.
                      <font size="2" face="Verdana, Helvetica, sans-serif">Anyone who doesn't bash those beautiful Sure-Piks will always be worthy of my respect [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                        Re: No Pindication
                        <font size="2" face="Verdana, Helvetica, sans-serif">Not as simple as that not my call thats up to head office
                          Re: No Pindication
                          the klixon is like a protection fuse and was more evident on the 82/30 when the pindication lights used to go off after a time delay.
                          maister
                            Re: No Pindication
                            Originally posted by Pin_Head:
                            </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 82/70 king:
                            <font size="2" face="Verdana, Helvetica, sans-serif">Not as simple as that not my call thats up to head office </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I hear ya, I know the feeling. But it is good advice and if at all possible I suggest it as well. OT boards are rock solid, plenty of guys will back me here. Install those babies and watch your chassis problems disappear
                              Re: No Pindication
                              Use aligator clips on your red/black leads across the klixon, set your VOM to AC amps (assuming it is capable of measuring current), to see what the draw is across it.
                              When the lights are on, you'll see '0', but when the klixon is open, you will see what the light circuit draws. Without pindication, the 1,2 and strike will draw LOTS less that the klixon is rated for - it was designed to handle the 10 pin lamps.
                              Now, I'll second and third the diagnosis by wb8yjf and Pinchezr.
                              Cheap fix - but not self resetting is to solder in a fuse holder.
                              Fancy fix - drill a hole in the chassis and mount a pop-out breaker.
                              Probably the recommended fix - replace it.
