brand new pins getting trashed
  • brand new pins getting trashed
    i have a lane that is putting rub marks on the belly of brand new pins but to top it off it actually gouges the head of the pin. i have never seen this before can anyone give me a good place to find out whats doing it
    When in doubt check at bowl-tech
    When people are around no cursing and throwing things
    Re: brand new pins getting trashed
    Check the plows for cracks. As the pins roll on the carpet waiting to be picked up by the pinwheel, the plow can scratch them if there are cracks. Also check the bin assembly for anything loose or sharp.
    Wang
      You may also want to check your spotting cups. Occasionally you may get a jagged edge on a cup and it could mark the pin as its being shuttled into the cup. Check your kickbacks for any exposed nails as well.
        i had this problem,i found out that it was the cushion plank,the housings had worn and the plank had lowered down a bit,the pins where getting caught under the cushion plank and the carpet was melting the plastic,which,when they went into the pin wheel,left gouge marks on the pins,like they had been melted around the middle.
          Rub marks on the bellies of the pins can also reusult from the cushion blocks wearing and causing the cushion to hang too low. The pins get trapped under the cushion plank and the carpet burns them!
          I'm Brian and so is my wife.......
          http://www.badassbowling.com
            HaHa!! Everton you beat me by 2 mins!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
              ok but where would the gouges in the neck come from
                Try looking in the bin, around the 4-7 pin area, look for tell tale signs of little white pieces of plastic. This happens when a pin is dropping into the bin hitting a piece of metal from an adjoing bin. Also the headpin giudes will do it but usually that will be more toward the belly of the pin.
                  I agree with Klixon/Wang on the head gouges, bin or plows. Wherever it is you'll get white shavings in that area, if its in the bin or shuttle you might see these shavings on the table somewhere.
                    <font size="2" face="Verdana, Helvetica, sans-serif">Sharp edge on turn pan near devil horn is a likely spot.
                      long flat gouges on the neck are usually pins falling off the o-pan and glancing the sharp side of the dizzy support bracket
                      im not 100% sure what might do the ones on the bellies
                      jez
                        if it is the cushion plank,you will find shavings on the dizzy pan and under the machine.
                          Plow cracks.
                            Plow has been responsible for a lot of pin damage, but i did have a lane that was scoring the bellies all the way around on ALL the pins. Took me a bit to figure it out. Kidney pan. Too high. Smooshing the pins against the pinwheel. Would actually stop the pinwheel intermittently. Plow is a great candidate. Also, think of all the crap a pin hits when its bouncing around your pindecks. Nails or screws a little tall in your kickback panels, underside of the table casting, etc.
                              Inside edge of the ball exit / ball exit ring... if it's cracked or ragged, it'll cause a lot of pin damage. The edge facing the pindeck is the most dmamging one. Corner pickoffs and solid corner shots kick the pin(s) towards the ball door edge, and when they hit the sharp edge, it scalps the bejesus out of 'em.
                              Scuffs in the belly are most commonly caused by pins rolling between the carpet and tailplank, but rolling against the plow (especially a cracked one), or just 'idling' on the carpet causes scuffing from the dirt and grit the carpet picks up, which essentially makes it like sandpaper to the pins.
                              And as was mentioned, other common areas are the wheel and orientor areas, covers off the pin holders in the bin (leaving the sharp metal in them exposed), sharp casting edges on the cups, and occasionally sharp or broken edges under the table casting that scrapes the pins on a solid hit that throws them upward into it.
