I have a table I have a problem with cups hitting pins when respotting and moving pin or knocking it over mainly the 3. I have done table adjustments and changed all bad yoke leg bearings,lightning rod bearings & pins,leveled table,changed bad rod end fittings,inspected table legs (have newer style),inspected pillow blocks & tourqe tube,flagged table,checked for warped cups. If I raise table more than specs it will only do this to the 3 pin. There is a messurement from the bottom of the frame of the side part that 3223 mounts to to the pindeck. the specs are 18 7/8 -19 inches. At the back row 10 side it is 19 3/16. The back row 7 side is 19 5/16. At head pin row it is 19 1/16 both sides. Is this the problem? If so how did it just start giving problems? If I do lower machine frame won't that make problem worst? Besides that lowering frame won't that call for a whole bunch of adjustments everywhere? Or have I overlooked something? I also moved chassis just for s##ts and giggles. The problem stayed. I was thinking about moving table motor, even though I see nothing but smooth operation, and moving table drive also. Also checking table drive shaft, key and splines. Anybody got a solution or suggestions? I thought about opening spotting rod gap more than specs to move pins back and adjust them forward cup by cup. Any thoughts on that as far as what problems that would cause? Any help????????????????
THANKS!!!THANKS!!!THANKS!!!
BAMM
BAMM
