  • 82/90
    hi all,
    just a quick question,
    does anyone know how to reset the frame count on a 82/90 1st generation chassis.
    many thanks
    dave
    Re: 82/90
    Hi Dave,
    On our 90's we use the Reset Option on the MCU. I just press the Lane Number and hit Reset, It seems to work fine for us.
    Where about in England are you? I am stuck way down in Newquay Cornwall.
    Andy
    JMF Bowl
      Re: 82/90
      evertonfc,
      There is a sequence of buttons you can push. I have the manual in my office, but I'm not there.
      I'll send myself an email so I can get it for you if no one else can find it first.
        Re: 82/90
        cheers ted,
        that would be great.
        dave
          Re: 82/90
          MCU has spec to reset internal frame counter.
          maister
            Re: 82/90
            Yeah, if someone knows it off hand. I'm still on the job and wont get to my book for several days.
            If I dont see the help here, evertonc, I'll post it when I get back.
            The XLs, I believe, cant be reset to 0. There are 2 parameters in the XLi, mechanic and bowled frames. the mechanic can be reset.
            But the orig. 90s can be reset from the chassis keypad, I just don't remember the sequence.
              Re: 82/90
              you cant reset the 1st gen from the MCU,as ted said,there is a way to reset them by using the keypad on the chassis,its just finding what it is!.
                Re: 82/90
                From the manual:
                Resetting the frame counter
                The internal frame counter for each lane counts the number of times the machine has cycled since the frame counter it was last reset. It is intended for maintenance purposes only.
                In order to reset this counter, press and hold both PROG ZERO keys for 4 seconds as in the Program Lane Number Mode. Instead of altering the lane number, press CYCLE to reset the frame counter for the respective lane.
                Hop this can help you further,
                Niels
                  Re: 82/90
                  cheers niels,
                  ill try that today,
                  thanks for your help
                  dave
                    Re: 82/90
                    works fine,thanks for your help
                    dave.
                      Re: 82/90
                      <font size="2" face="Verdana, Helvetica, sans-serif">I have managed to reset a 90XL chassis frame count to '0' once accidently. Would like to know if there is a way cos they seem to reset themselves at around 65,500 frames.
                        Re: 82/90
                        Originally posted by cassenior:
                        ...they seem to reset themselves at around 65,500 frames.
                        <font size="2" face="Verdana, Helvetica, sans-serif">The number after 65,535 is 0. That value - 2 to the power of 16 minus one - is the largest unsigned value that can be represented in a 16 bit word.
                        deb
                          Re: 82/90
                          Deb....did you change your screen name???
