distributor belt slipping
  • distributor belt slipping
    I have a machine that I just put a new distributor belt on, and it keeps slipping off to the 10 pin side... I have a feeling it might be too long, but I thought I'd throw it out there before I go cutting it... any other suggestions??
    Marc
    Re: distributor belt slipping
    Take it off and change directions it rotates.
    If this does not work you may have to bend the belt tensioner bracket slightly to improve tracking.
      ok... I did that, and it's still happening, but now I see why, I just don't know how to fix it... the roller that the belt tightener spring attaches to, is pulled so far forward, that it's rubbing the belt against the bar that holds the non-adjustable rear roller... I don't know how to fix it... HELP!!!
      Marc
        It's Too Long and needs cut// (shortenend)
          Some items to check:
          Is it the right lenght for it's thickness
          Is the belt lacing installed square on both ends
          Are the eccentrics in good shape and adjusted correctly, little to no sloppiness in the carraige.
          Is the tracking bracket roller in line with the rear carraige roller, it can be adjusted side to side.
          Sometimes tweaking the tracking bracket angle by using a screwdriver between the vertical links will help.
          You can call me if you like, 804-240-4982.
          John
          John
          804-240-4982
            Is it the correct tension spring? If the spring is too weak you wont have proper tension.
            Without Mechanics Where Would We Be?
              Most of the Dizzy belts are to long when you get them. They need to be trimmed to length. If it's just rubbing on the frame, shorten the belt 1"
                measurement would be 116 1/4" give or take 1/4" i believe
                Qualified to do anything with nothing!
                Ball Returns Shorted Out?
                Trip rocker arm
                Lower ball cushion board
                Backend motor plug
                82/70 combi motors
