table problem
  • table problem
    Hi guys. I am having a problem with a table motor. When motor starts, I am getting a grinding/chattering noise. Motor is getting VERY hot, and eventually kicks wall breaker. Here's what weve done... c-1 sockets are new, changed chassis, changed motor with sweep still grinds, swapped gearboxes with sweep... same, SSSS from Stal's changed... same, control box breaker, table switch, new wires to motor plug, new capacitors, we're now lost... PLEASE HELP!!!! Any ideas??? Thanks all!
    Re: table problem
    check the bearing on the table driveshaft. take the gearbox off and try to spin the shaft by hand. you could have a siezed bearing.
    SGT
    U.S. Army/AVN
    Retired
      Re: table problem
      forgot, you will also have to take all the weight from the table off of the shaft
      SGT
      U.S. Army/AVN
      Retired
        Re: table problem
        When you crank the table motor is it binding or does it manually crank ok What kind of motor is it National -- West?If its not mmechanical than your voltage should be checked. check your c2 plug also.
          Re: table problem
          while cranking by hand, everything feels fine. If bearing was bad wouldn't there be some resistance? I'll check it out though. Thanks LaRue
            Re: table problem
            Does the motor actually turn? If not, it sounds like the start circuit is not functioning (which has many causes, but typically the capacitors or the start switch).
            Try the sweep plug in the table motor and the table plug in the sweep motor. This will tell you if the problem is in the electrical/machine side, or the motor/mechanical side.
            That it trips the wall breaker rather than the klixon is of concern.
            Did you try running the motor while it wasn't on the machine (i.e. a bench tester)? Have you looked inside the motor? Does the wiring look healthy?
            Regards,
            Andrew.
              Re: table problem
              Hi Brian.. Nationals. Voltage to be checked tomorrow(meter not available today). What am I looking for in the c2-a?
                Re: table problem
                Also, could the spot solenoid have anything to do with this? Too much draw maybe? Thanks again!
                  Re: table problem
                  Just make sure all your pins look good in the c2 doesnt hurt to check .If you think you may have a problem with spot solenoid disconnect it.elimate that possibility.With it blowing the breaker on the wall youve gotta be drawing a lot of juice check inside the wireway make sure there isnt a screw lying across terminals that go to your table motor plug.You said youve changed the plug do try swapping sweep and table plugs as Andrew suggested.The problem should move with itAlso if all else fails check your sweep reverse switch in reaer control box Ive had those go bad and cause similar problems.good luck Ill check in with you tommorrow.Brian
                    Re: table problem
                    Posted by bent wrench:
                    Also, could the spot solenoid have anything to do with this? Too much draw maybe? Thanks again.
                    __________________________________________________ _________
                    Machine peak draw is around 24-26 amps for just a moment. Not enough to throw the breaker unless it is holding there.
                    If you do have a Stahl's motor start relay in the wireway. Go to the motor head and see if the two start switch wires may be touching ground. These wires will be fastened together and must be covered with some sort of insulating material.
                      Re: table problem
                      o.k. all thanks for all your replies. i will check all tomorrow and let you all know. again.. THANKS!
                        Re: table problem
                        check in the wireways for a foreign object shorting across any of the table power wire terminals.sounds like it could be failing to get full power and or a short to ground.
                        maister
                          Re: table problem
                          Bent Wrench Does the table relay chatter only when its spotting pins? If so it could be that the M relay is dropping in and out because of the counter on the framemeter. If you unhook terminals 5&6 in the AMC box,taking out the front end wiring, and then just jump the terminals to turn on the machine and it runs OK you have something wrong in the Framemeter box.
                          Good luck Paul
