need to change wires for sweep reverse
  • need to change wires for sweep reverse
    can anyone tell me the wires
    i need to change for sweep reverse ?
    (Accuscore+ MP chassis)
    after a gutter ball on first ball my machines (9 -16)
    will sweep all pins off deck instead of going back up.
    i know amf sells kits but im in a bit of a crunce for time and cant even order till monday
    i can do the wires i just need to know the pins and ta's thx in advance
    ever jump down to the deck and spray miracle grow on dead wood ?
    Re: need to change wires for sweep reverse
    Did you just install the MP's?
    The wires should be there.
      yea , just installed them , replacing the ss ones
      these machines are older and do not have the 4 white wires for sweep reverse, these only have 3 white.
        I hope you can read the pins and TSA's on my ugly drawing
        Is this what you need??
        So it goes.
          I think so , do u know what the wire difference is between the old 70's and the newer ones ?
          i can trace the wires if need be
          and will be alot easier with your map
          thank you
            I still use an AMF drawing from 1962 without problems.
            So it goes.
              Like King said, wires should be there. Do the C1 plu/receptacles have any orphaned pins? If so, I would check there. Otherwise, I would be looking at the M2 relay. This is your SWSR relay for pickoff. Also bear in mind that ALL 3 ice cube relays are now 24 VAC whereas the SS units had 2 of them and the Spot relay was 10 VDC.
              Do you have a 5500 drawing? They will give you the breakdown of what should be there.
                Sweep reverse requires the four wires into the C1 plug and connected to the sweep motor cables in the wireway i will try to find my drawings next time i am home.if they are wrongly installed sweep motor will buzz and klixon will trip.There is also the scoring cable to the rear control box which i presume has been installed correctly.red and Black pair to cycle switch and white to sweep switch and black of this pair to ground.
                maister
                  Lampie, that's old, i have only white wires with printed numbers.
                  <a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank"><a href="http://peet-peet.tk" target="_blank">http://peet-peet.tk</a></a></a></a></a></a></a></a></a>
                  Peter
                    I think nut has figured it out. Its been 2 weeks without a responce.
