New pins head first out of elevator
  • New pins head first out of elevator
    We just put new pins in about 3 weeks ago. Nothing a minor adjustment here and there couldn't fix at first.
    Now, three lanes are having problems with pins coming up head first missing the fork on the turn pan completely. Causing them to come up the dist head first. Tonight all three lanes are acting up badly all together. Looking for some more options to look at tonight after league if anybody can respond ASAP.
    Also, if anybody has the specs to some of the mods I've seen for distributors, I'd gladly take them at this adress. jason@mwisp.net
    Thank you.
    Re: New pins head first out of elevator
    Try taking your kidney pan put it down as low as it can go vertically by loosening the nuts on the backside.Then loosen the nuts on the inside lower the bottom of the kinney all the way.then raise the front until your pin is snug. A good starting point you may have to tweak it a bit but you shouldnt get head first pins give it a try.
      Catfish, check out the Distributor rear belt runners / O pan guides thread. You'll find a mod that will eliminate head first feeds.
        Also try adjusting dist pan back closer to pinwheel. Had the same problem you describe about a week ago.
          What kind of pins?
          Adjust the kidney to release them later.
            Use stock 6" pulley's. Our house runs just fine. I know that nobody will agree with this!!!
              <font size="2" face="Verdana, Helvetica, sans-serif">yknow, thats a thought i too had recently. I ripped all mine off and put 4 or 5" inch sheaves from Grainger on my pinwheels.
              Then I saw the thread about removing the belt runners from the dizzies and I did it on a few lanes. I really like the way they look, but dammit if those arent the only lanes I have occasional pileups on.
              Seems like without the belt runner, the pins sag on the belt (no belt runner, makes sense) and dont orient as fast. So I, too, was thinking of speeding up the wheel. I wouldnt mind hearing some feedback on that either. Good luck to you.
                Jerry - Amflite II's.
                Kidneys were adjusted once more last night and the head first issue was resolved on 2 of 3. Lets see how long it lasts.
                  BG - Thats exactly the mod I was thinking of. I forgot where it was. Thank you. I will try and convince the boss to give it a shot ASAP.
                    Get some of Ed Fox's turn pan wipes and put them on. Adjust pin guides and your orientation will improve.
                    Ed did not pay me for this nor am I a stockholder for a wipe company. Just stating my great luck with turn pan wipes. They work well.
                      6"pulleys and the new AMF belt,no better combination.Feliz Dia.
                        Go with the opan wipes. The pins roll off instead of slide off, so you can adjust your kidney to let them come of later and they wont over swing. Personally, I like the 5" pulleys and B188 belts.
                          We have the same setup here as Smokey. Adjustable pulleys, B-188 belts, and wipes. Great results with this setup (1 jam a week if lucky.)
                            We have 5" pulleys 188" belts 1 or 2 pileups a week. ave. 2 centers 60 lanes.
                              Is there a part# and a phone# so I can tryout the pan wipes?
