SS Chassis problem 3
  • SS Chassis problem 3
    Yayyy hi again fellas LOL,
    Here is my 3rd SS chassis problem, whats up with this one is that i have no 1st ball light, it still scores fine machine works fine just no 1st ball light again changed boards with working boards from another chassis,
    Again ideas would be appreciated,
    Cheers Brett
    Re: SS Chassis problem 3
    Probably a bad connection in the elco plug. I had one a while back with no 2nd ball light, it was a bad connection there. Give them a good eyeballing, if any pins look spread gently (and I do mean GENTLY) crimp them back together. Be careful doing this as you can break them rather easily
      Check the small resistors/diodes in the motherboard between the #6 slot and the elco plug.
        Check the Light bulb. Remember you start simple & work your way from there.
          If the problem moves with the chassis (I assume you've tried that), then it's likely to be the Elco plug pins as Rep suggested.
          Elco plug is a pain in the ar$e. It was worse when we had 5 boards, simply because we had to change the chassis more often (and every time you unplug the elco plug, it losens the pins a bit). We ended up replacing the Elco plugs with cannon plugs (far better).
          Note that those 20 diodes on the motherboard near the 4 board are for the pin lamps and sparemaker.
          Cheers,
          Andrew.
            <font size="2" face="Verdana, Helvetica, sans-serif">SIMPLE??? that sounds like ME LMAO my bad fellas, my night tech just rang me saying while he was on lane 1 he noticed that the masking unit wires had broken where the 1st ball LED's are LMAO hahahahahahaha
