NEWBIE NEEDS HELP
  • NEWBIE NEEDS HELP
    HI GUYS . I HAVE A MACHINE THAT HAS A STRIKE CYCLE ONLY WHEN I UNPLUG A WIRE ON THE SWEEP ARM FOR SCORING. I,M A BRUNSWICK GUY WITH 82-70 AND ACCUSCORE. CAN SOME ONE PLEASE HELP ?
    Re: NEWBIE NEEDS HELP
    Hi mate,
    On your machines is strike cycle determined via the camera or respot cell wires? Also do you have 5 boards, XOP's or Omega-Tek boards? When you bowl does the Accuscore score a Strike or not?
      OMEGA TEK BOARDS , AND WITH THE WIRE UNPLUGED IT DOES NOT SCORE AT ALL . IF I PLUG WIRE BACK IN IT SCORES BUT HAS NO STRIKE CYCLE
        You running a camera ??
        Are all the wires attached to your respot cells?
        Little more info would help.
          You can put a rag / cloth over the camera and cycle the machine. It should run a strike cycle.
          If not replace the camera / pcb's. Use the targets to adjust the camera to ensure that it can see all ten pins.
            All wires attached to respot cells . With scorers on or off does not have a strike cycle withtaht wire attached , take it off and I have one
              Your camera is seeing something that isnt there.You need to replace or adjust your camera.Do you have expander boards in your chassis? They allow short strike cycle and sweep reverse on gutter ball or 7 10 pickoff.If it isnt your camera we can elaborate further.
                YES I HAVE EXPANDER BOARDS IN . THIS WILL HAPPEN EVEN IF THE SCORER IS OFF ?
                  You still haven’t answered if you have cameras. If so try Alastair’s method of blacking out the camera with the scoring on.
                  If you got a strike cycle (with the rag on)then you have some other light source the camera is picking up such as a torn curtain or shiny spot on your sweep arms. Either that or the camera needs re-adjusted
                  What is the count displayed on the monitor?
                  Triac
                    Try swapping out the Omega Tek MK-70 board. If you have cells attached, it may be seeing a pin that not there (due to bad MK-70)
                      What type of Accuscore is it. Hehe
                      Try changing that switch. they only cost $4 and go bad sometimes.
                        THANKS FOR THE HELP EVERYBODY . THE SWITCH ON THE SWEEP ARM WAS NO GOOD .
                          Nice call JJ…you da man.
                          Bam glad you got it and thanks for posting back with the solution. A lot of newbies don’t do this an I become reluctant helping these people anymore.
                          BTW…Welcome to Bowl Tech
                          Triac
