I just came into 20 lanes worth of PBLs. Ive read about these things enough to know there are several types. The ones I got have the standard looking PBL clutch (??? for a lack of a better term) on the left which is hooked up to the lift arm in the ball opening. They have a standard mousetrap style paddle except that its tensioner spring hooks to the frame of the machine instead of inside the trap itself, which I like. Is this enough info to tell me what I have?
Also, the lifts have very small, high speed pulleys. To make up the difference, the paddles have huge, low speed pulleys. Is this normal for PBLs or would it be an advantage to put bigger pulleys on the lift?
To install these, Im going to have to drill a 1 5/8" hole in that thick 8230 sideplate. Is there any easy way to do this besides pulling out the sawzall? Does anyone make a hole saw stout enough to accomplish this.
Also, any tips to get the most out of these would be appreciated. Thanks.
