PIN FEED ?
Re: PIN FEED ?
Could also be that your dist is too high. I like mine set so the trip fingers when pushed down clear the butt guids by about 1/2 to 1 inch, I find that lets the pin fall flatter. Also, check your head pin rails, make sure the stringer isnt busted at the hole. This could change the angle of the rails.
Re: PIN FEED ?
Check the pin butt-guide of bin1. This one is a bit hidden.
It might be cracked or the schock mounts attached to it.
Re: PIN FEED ?
BUFFLO JIM I HAD THAT PROM. EASY WAY TO FIX IS TAKE TRACK ASSEMBLY OFF & LOWER THE BACK OF THEM DRILL NEW HOLES SO IT FEEDS THE PINS MORE LEVEL WHEN THE PIN COMES OFF OF DIST.
Re: PIN FEED ?
Re: PIN FEED ?
I have a question, does it do it all the time, or only after a strike cycle? I had a machine that would only do it after a strike cycle, the dist. would let the pin off just about the time the shuttle shuttled the pins, right thru the shuttle. A quick fix was to add an extra pin to the rack, that way there will usually be 2 pins in the headpin slot.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
