Looking For Monitors For Xll Strike Scoring
  • Looking For Monitors For Xll Strike Scoring
    Can anybody help me find monitors (new or used)For twelve strike Scoring??? Desperate & Confused
    AMF? Ain't My Fault!
    Re: Looking For Monitors For Xll Strike Scoring
    <font size="2" face="Verdana, Helvetica, sans-serif">Uppers or lowers?
    Please buy MADE IN USA!
      Lowers. Hope you can help. Tanx,Ed.
        I belive we have a supply of them in storage here.
        If you want me to I can check with boss on cost.
          Yeah, That would be great,Muzz. Preciate it.
            I just got time to check the board. He is gone for the day I will talk with him Fri.
              They are just a regular moniter from any computer. go to any computer shop and pick one up. if you cant I have a couple extras.
              curt
                If your lower monitors are blacking out do not throw them away yet. They black out often and there is a simple cure. Remove the back cover. With the power off, discharge the crt by using a long plastic or rubber handled plain screwdriver with a wire attached to it going to a good ground. Slide the tip of the screw driver under the rubber boot attached to the crt. It should snap or pop (use caution because you're dischargeing several thousands of volts)
                discharge the crt several times, then apply power to it without it being hook up to the cpu and you will get the default colors to appear on the screen. green, red and blue. If not,remove power, use an ohm meter with it on continuity.
                Apply the two test leads to the fuse on the circut board and then the crt should work just fine.
                If you still need crt's go to e-bay and they usually run from 15-40$
                peter senf
                  Uh, about 35,000 volts.... [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] DO BE careful! I've been bit many times &amp; it ain't fun...
                  Ball Returns Shorted Out?
                  Trip rocker arm
                  Lower ball cushion board
                  Backend motor plug
                  82/70 combi motors
