I now have a S.S. chassis that will not spot pins. Problem moves with chassis. Changed spot relay, no go. Chassis is somewhat newly wired, and new relay socket was installed, but all looks well there. When holding down spot latch to force to pindeck, table will stop at bottom dead center, but will return to "0" with TA1. Closed G.E. contactors. Could that be it? Thanks for all the help in advance!
Yet another s.s. chassis "Q"
Re: Yet another s.s. chassis "Q"
what does it do when you dont interfere? Does it run at all? Need some more info here. Excluding the table stoping at the deck, I would have to wonder if the solenoid is just not engaging. (start with the s relay, the 10v one) but as to the table stoping at the deck. What type of boards, and have you swaped them out?
Try the s relay then. Swap it to another chassis. It is the only one that is 10 v. the other 2 will be 24. that is the relay that controls your spot solenoid. It could also be a bad relay socket. Maybe a bad solenoid. The return srping could be too tight (under the solenoid its self) If you have time, unplug the solenoid, put a meter on those to wires, and see if you are getting juice to the solenoid when you cycle the machine.
Are you saying that the table only stops at the bottom if you hold down the latch with your hand? That seems strange (since the latch has no relation to the electrical system - unless somehow the table is engaing the offspot input on a long stroke??).
Does it change symptoms if you put two pins in the #9 bin (or hold it with your hand to stop it opening after the pin has fallen into the cup)?
Is the table driving to the bottom (i.e. contactor is on), or is is just coasting to the bottom (with contactor off)?
Regards,
Andrew.
