well now that the 70's are in and running smoother,
I have yet to wire up the ball returns to the A&MC
box so the wheels run 24/7 and the hand driers do not run (have the toggle set to Aux right now)
but now i want to get them wired back in.
so where do they go ?
the diagram in the AMC says for ball check is
3A and 3B is this correct cuz it wont work more than 2 secs when toggle is on normal with lanes turned on
82/70 with MP chassis 9800 board
ever jump down to the deck and spray miracle grow on dead wood ?
yes terminal 3 in the a&mc box is for your underlanes. if im correct, one wire runs to ts 2 #2 and the other to ts 2 #3 in your sure stuck box. if im wrong, someone will correct me.
Loose Nut--- When they were hooked up to the 30s ppwer to the relays was supplied by the machines. You have to pick up 24 volts from a transformer in front end and use 1 two conducter as a switchleg back to the A&MC box.
