Pin Wheel
  • Pin Wheel
    Where the pin wheel bolts to the ring with carriage bolts the bolts have been lose resulting in elongated square holes. Besides replacing the pin wheel is there a fix for this? Maybe cut the old bolts off and use 5/16 carriage bolts or use the 1/4 20 bolts with 2 jam nuts and permanent loc-tite? What do you guys do when you run into this?
    Well we're safe for now. Thank God we're in a Bowling Center.
    Re: Pin Wheel
    the holes are meant to be square
    we use 1/4 cup head bolts and cone lock nuts
      Re: Pin Wheel
      We only had a couple like that... we used steel 1/4-20 round head machine screws with loc-tite and Stover nuts... we figured using round heads instead of hex heads would save a litle bit of nicking on the pins.
        Re: Pin Wheel
        I have been forced to use Aleens before. Worked good in a pinch. (pan head)
          Re: Pin Wheel
          same here. I just use "Button Head" bolts
            Re: Pin Wheel
            Jim and Homer the "button head sounds like the fix. The allen slot being so small hopefully won't scratch the pins.
              Re: Pin Wheel
              Loctite #680 is the strongest. It works for oilite bearings too. Instead of throwing the part away like lightening rods, RSC knurled pins, spotting mechanism oilites when they are turning in the casting and anywhere a press fit is required and as 'G' stated, on rd. hd. screws to hold them in place.
              Ball Returns Shorted Out?
              Trip rocker arm
              Lower ball cushion board
              Backend motor plug
              82/70 combi motors
