Vantage Spotting Cup Problem
  • Vantage Spotting Cup Problem
    Anyone having problems with Vantage spotting cups being very rough and not spotting pins correctly
    Re: Vantage Spotting Cup Problem
    No…Did you check the bottom gap? Have you tried an AMF cup with the same gap to verify the cup is defective?
    Triac
      We have tried all the aftermarket manufactures and on this one we have found there is nothing better than genuine AMF cup. We have had issues with all the others. The worst one is the plastic cup.
      Tim
      HBOwner
        I have a lot of the vantage plastics and have no problem with them. I think they are just as good as the orignal AMF ones. Make sure the table is level to the pin deck and spotting at the right hight.
          Never liked Vantage cups. AMF's only for me
            I cant exactly say the ones I have had problems with, but they 'J'ust are 'Crapy' in my o P ion. I am not allowed to say anyting negitave anymore about...... well anything....so...well... thats all I can say about that.....
              Vantage cups are set at a different angle than the OEM cups. I took them all out and sent them to recycle.
