sweep shaking
  • sweep shaking
    OK WE HAD A BROKEN STABILIZING LINK FOR THE SWEEP AND WE WENT A REPLACED IT AND PUT EVERYTHING BACK TO THE WAY IT WAS..AND NOW OUR SWEEP SHAKES REALLY BAD WHEN IT TRAVELS TO THE BACK OF THE DECK AND SPUTTERS HORRIBLY WHEN IT FOWRDS BACK TO THE FRONT OF THE DECK
    ANYH IDEAS
    Re: sweep shaking
    Try the sweep drive link on the sweep shaft. this is the arm that drives the whole sweep assembly . what happens is the hole the in the link gets opend up ususaly from a bolt being a little loose and you get what you are describing that could have also contributed to the stabilizer link getting broke.
      Re: sweep shaking
      Your Sweep may be running too far into the pit. This will make them run rough out to the front.
        Re: sweep shaking
        That would be the link is to long.If so shorten it and that could also break the stabilizer link.
          Re: sweep shaking
          Sticky rubber bumpers will contribute too, but it will be a single jump as the rubber comes off the arm.
            Re: sweep shaking
            I'm with lafarge...
