sweep reverse humming
  • sweep reverse humming
    82-70, 9800 series mp. When you try sweep rev. all it does is hum really loud. Have tried several different chassis, motors,caps and even changed gearboxs. I have traced all wires and found good. no trash in the wireways or burnt pins in the c1 or c2. tried changing the sw.rev. switch all to no avail. If you push on the sweep control arm while it is humming it will start. Other than that I am at a total loss. any and all suggestions will be gladly accepted. NOTE: had a wire come off the csm-2 cap and shorted against the wireway. That is when all the fun began.
    SGT
    U.S. Army/AVN
    Retired
    Re: sweep reverse humming
    Have you changed the M2 relay and the MP board?
      yes. have completely changed chassis. Even tried an Ultra 98 same result.
      SGT
      U.S. Army/AVN
      Retired
        are you still running mechanical/centrifical switch motors?
        It's been awhile but I have much more to share!!!
          BAD ct-connection in female motor plug.
          I can't explain why it's working in forward and not in reverse....This JUST happened to me....
          So it goes.
            Perhaps it forgot the words? [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
              electronic start switches. Lampie i'll have to double check that. Already tore apart once but I'll check again. right now it is time for bed. Be back in the morning.
              SGT
              U.S. Army/AVN
              Retired
                What type of soild state start switch are you running? If you're using the AMF one make sure that you have made the changes in the wireway to bring back the sweep reverse into the sweep motor. I'm using the Bowltronics start switch in my mp's. In machines with the 9860 board, I have had a problem with the motor kicking the overload out when the motor does the sweep reverse overtravel. It seem that the circuit is switching to fast for the start switch and the motor does not know which way to go. I've taken the ss switches out of these machine, and put them on the table motor. Since going back to the mechanical switches I've had no more trouble with the machine and their sweep motors.
                AMF DOCTOR
                The doctor makes house calls.
                AMF DOCTOR
                  AMF DOCTOR
                    could not sleep. Doctor, what changes are you talking about? Can you send them to me or tell me them. I've never had a problem going from mech. to ss before. If there is a solution out there i'll take it.
                    SGT
                    U.S. Army/AVN
                    Retired
                      The first question that needs to be answered is did this just happen or has it been that way for a while? Did you just put on an electronic start switch? If you did just put on an electonic start switch, you need to do the wire way mod to allow for sweep reverse.
                      It is as follows:
                      Remove red wire on TSA - 2 that comes from sweep motor cable and move to TS 23
                      Remove blue wire on TS 23(L133 for an even machine and R133 for an odd machine) and move to TS 17 or 1A1.
                      Remove white wire #8 on TS 17 or 1A1 that comes from sweep motor capacitors and place on TSA - 2.
                      Now you sweep reverse will work with Electronic start switch or a cent mech. It doesn't matter which type of motor is on with this conversion.
                      Wang
                        wang, thanks alot. yes we did just change it to electronic. since it is still apart i will check for the mod in the morning. will let ya'll know something tommorrow
                        SGT
                        U.S. Army/AVN
                        Retired
                          what brand of SSSS is it?
                          Wang
                            AMF
                            SGT
                            U.S. Army/AVN
                            Retired
                              If it was a Solid State machine previously, use this instruction sheet.
                              If it has always been an MP machine, use this instruction sheet.
                              Notice the note at the bottom, our very own Dewbowler thunk it up!
