Slowing down pin wheel
  • Slowing down pin wheel
    I have slowed down everything on my A2's, has anyone found a pulley size that works great on the 70's?
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Re: Slowing down pin wheel
    I use the ones that AMF put on. Seems to work ok for me.
      I use the 5 inchers drom Stahls. They are about $10 a piece (for pin wheel) you may need to replace the 190 inch belt with a 188, stahls also has them. AMF has an adjustable one, but it is like $55. I also use the 5 inch ball lift pullies (biger) to slow down my lift. I tend to get them from vantage. The EBN reduction sheave is great to slow down your paddle, if you dont have LBS.
        I have the LBS but the guys want to try the 5" pulley so I thought I would check on here and then order 12 of them and see if they help things out a little. Did you have to change the belt on the XLI's or are they all 190"?
        thanks Paul
        Drill
        David Bolt
        Champaign, IL
        USBC Silver Coach
        IBPSIA BOD
        IBPSIA Advanced
        Technical Certified
        Pro Shops
          Drill you will have to readjust all of the kidnys to make the pins roll out a little later to get the turn needed for good orientation. Good luck you will like them.
            On 90's, the Boxes are geared down to slow down the elevator. We actualy had to put the big pulleys and belta back on that pair.
              I have a mix of 5 and 6 inchers. I try to only use the 5's where no matter what I try, I just can't get good orienting. Kidney adjustment is crutial, or head first pins will prevail.
                Drill give me a ring today...919.468-8684
                Peanut
                  I have always ran OEM pulleys with no problem.
                    All adjustable pulleys here. I've slowed down my pinwheels the maximum and have installed the B-188 belts. Orientation problems are non-existent. I've seen guys get the 5 inchers from Grainger with good success. Yes, you will have to dik around with the kidney adjustment, but once you've got it dialed in, you leave it alone.
                      5" pulleys and 188" belts 70s with 90 upgrade and they work great.Im not so sure that the motor is slowed down on the upgraded motor is it?
                        <font size="2" face="Verdana, Helvetica, sans-serif">I just got back in town or I would have called but will do so first thing Monday.
                        Drill
                        David Bolt
                        Champaign, IL
                        USBC Silver Coach
                        IBPSIA BOD
                        IBPSIA Advanced
                        Technical Certified
                        Pro Shops
                          <font size="2" face="Verdana, Helvetica, sans-serif">They were on the XLI upgrade we got. I dont know how long this geardown has been used, it may be new. Not sure.
                            Im not sure either thanks for replying Paul Ill research it more.
                              Do not go smaller than 5".
                              Ball Returns Shorted Out?
                              Trip rocker arm
                              Lower ball cushion board
                              Backend motor plug
                              82/70 combi motors
