continous spotting
  • continous spotting
    I have a lane that runs fine then out of the blue
    it starts spotting over and over and over.
    Its not the chassis i've tried 3 different ones
    and still does it.My guess is that its the T1
    SWITCH any other ideas.Ran fine for 2 days then it
    started doing it again.Any help would be appreciated. Scooter
    Re: continous spotting
    what type of scoring/ball triggering do you have? either of these can create this...
    It's been awhile but I have much more to share!!!
      accuscore plus
      zot triggering
        I should have added sweep stays down doesn't do
        anything then the table spots over and over sweep
        stays down at guard position.
          that sounds like it could be a chassis problem...what are you running? Oh, and just out of curiousity, 82/70's right?
          Wait, Saturday morning and I lose track sometimes. Forgot you said you tried different chassis already....
          I know I have had this happen before but I am at a loss for the moment?
            Screw or other debris on TS.
            TA-2 starts sweep up unless you have 5 boards, then it's TA-1.
            SB starts table spotting on all series.
            C
