continous spotting fixed
  • continous spotting fixed
    It was the TA1 switch top connectors were loose
    causing wires to touch bracket (METAL)causing it to ground itself out and keeping switch engaged.
    thanks scooter
    Re: continous spotting fixed
    Glad you found it!
    Ball Returns Shorted Out?
    Trip rocker arm
    Lower ball cushion board
    Backend motor plug
    82/70 combi motors
