Hi, can somebody tell me how to set the specs on a 8290xl first gen. chassis, in a manual I have it says select lane (even/odd) then press spec till all leds come up, then press spec again within 10 sec,then enter the spec.code and leds go off within 10 secs and new setting should be there.I tried this but nothing seems to happen, I´m talking about spec 29 Radary on. Tried it with an MCU but it had the wrong software version. Thnx.
82-90xl F.G.
