thanks all, Jeremy
ge/westinghouse motor running backwards
title says it all, changed a bearing motor still didnt want to run on its own, checked wiring under cap board needed replacement now motor runs backwards, i have even grabbed a motor to put over the stator and still the same problem, help please!
thanks all, Jeremyjust feeling my way out like a blind man at an orgy.Tags: None
Re: ge/westinghouse motor running backwards
I assume this is a B.E. motor? Swap the red and black wries on the switch. I believe its 1 and 3.Don't mind me, what you read is invisible.
J.D. I'll agree!If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
You should have 4 wires for single voltage or 6 wires for dual voltage
i think its about 4 ohms for your start windings and approx 2.8 or there abouts for your run.AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
thanks for all your help guys, got it figured out. sorry it took so long to reply i had to do some repairs to my dizzy that turned backwards, i have never seen one that bad before, it was in fact wires backwards. thanks again for all your help.just feeling my way out like a blind man at an orgy.
Heres a tip i learnt J-man when putting another b/e stator on a gearbox disconnect the dizzy drive shaft before switching on power to test directional run of the motor.
Cheers BrettAS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
