Distributor trip fingers
  • Distributor trip fingers
    I have noticed some differances between machines on the trip fingers width. Is there a set distance or a guide to go off of? Usally if it looks to wide then I move/bend them in for better indexing. Just curious of the thoughts of everyone on this.
    Re: Distributor trip fingers
    I kinda like them a little wider if possible that way when the pins leave the Distributor at the 7 and 10 positions it has more room to clear the fingers. Just my to cents.
      Wider is better unless it is female.
        LMFAO.
          I concure on both.
            FWIW, the closer the indexing levers are together, the faster the pin will slide off into the bin pocket. You can spread the indexing levers to slow down the pin's travel into the bins; useful if you're using a really agressive belt that has a tendency to overshoot pins past the butt guides.
              <font size="2" face="Verdana, Helvetica, sans-serif">[img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
              I should have guessed that answer from you king
