No Spot Mp Chassis
No Spot Mp Chassis
Need some help. I have a mp chassis that won't spot pins. We have tryed the mp board all the relays its in the chassis. Also the sweep switch on the side of the chassis was disconnected when I wire it back in I can't get the chassis to program zero, so it won't run.Tags: None
Re: No Spot Mp Chassis
Fisrt of all, do you definately have power to the solenoid then if you haven't,
Could be a bad socket for the relay in the chassis. Try replacing that first, if you don't have voltage.
Are you sure the solenoid is working ?
Could be the cams, a cam set up wouldn't hurt.
If solenoid is engaging, but there is no spotting you probably have a problem with the little black legs under the solenoid being worn.
Members
- Feb 2004
- 850
- 82/30,82/70,82/90,XL,XLI
- AMF and Qubica
- Various
- wood and synthetic
- 1953
check board connections at base of chassis and also spot relay.sounds strange but could you have an instructomat problem.
maister
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
