Mp Chassis No Spot 2
  • Mp Chassis No Spot 2
    Thank you bowl tech members. We found the problem with the mp chassis it was t22 on table relay that goes to #6 on spot relay the wire wasn cripped on the plastic not on the bear wire.
    Re: Mp Chassis No Spot 2
    Good job.
    SGT
    U.S. Army/AVN
    Retired
      thanks for letting us know the solution, you may have helped someone else out there also.
      maister.
