Franklin Back End Motor
Pulled a backend motor off of a lane that stopped working. It's a Franklin rotor/stator and there is a YELLOW wire that comes out of the windings that is going to nothing. Can't see where it might go. No obvious terminals missing. Any help appreciated.The impossible often has a kind of integrity to it which the merely improbable lacks.Tags: None
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
