need a diagram of sweep/table motor
  • need a diagram of sweep/table motor
    was wondering if any of you good people out there would happen to have a diagram/exploded wiew for westinghouse sweep and table motor combo. and if its in your good graces a exploded view of the gear box?
    thanks for your help and happy holidays.
    Cheers, Jeremy
    just feeling my way out like a blind man at an orgy.
    Re: need a diagram of sweep/table motor
    Jeremy,
    I am pretty sure I have the manual with all of that info. I'll make a copy of it for the cost of copying and postage. Let me know....you can P.M. me if you want.
    Jon
      Cheers, Jeremy
      <font size="2" face="Verdana, Helvetica, sans-serif">If all else fails, I'll take out the .50 Cal and explode one for you... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        G-man
        you do the motor and I'll do the gear box. Just happen to have something laying around that should work. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
          now..now....
            J-man; I had one apart before BT and digital cameras... It cost me more for parts than I could buy a used motor for. The orbital bearings/gears will run you about $350.
              ill check it out felix, thanx guys.
              btw, .50 cal sounds bout right to do the job [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
