At the 30 hour a week part time gig, I have the pleasure of 3 pair with Lazy susan returns. (the rest have been converted to c-90's) I have 2 pair that struggle with 6 and 7 lb balls. they come up the uptrack to a point they just touch the leather strap, and then slide down. They dont even make it to the wheel. Any suggestions on how to get the lighter balls moving a hair faster. I played around with 1 yesterday, (it wouldent return anything less than 10) and got it picking up 9's and 10's (new strap) I was considering trying some Life long 'green things' to speed up the ball comming off the lift in back, but am supposed to have the last 3 c-90 units in b4 March, so I would hate to spend the $$...any suggestions would be appriciated.
Lazy Susans.
Re: Lazy Susans.
We have black urithane wheels...I will look for the guts from previously removed ones to see if we have better ones, but the light balls never touch the wheel, so I dont believe it to be the problem. We have the rubber curtian savers off the cusions inbetween the belt and frame.
Re: Lazy Susans.
Might help a little to put a block behind the downsweep to keep it from flexing. Plus check the underlane to make sure nothing is slowing the ball.
If that doesn't work, for $3 cash/hour, there are migrants out of work this winter - they can sit at each lift and be the ball booster!.
Re: Lazy Susans.
If it's wood downsweeps, you can scuff them sideways with a gritty sandpaper to induce more roll as the ball comes down. If the ball is skidding down the downsweep, of course, it won't be able to drive up the upsweep as hard.
That is one of Carl's old tricks.
Re: Lazy Susans.
Dutch had a good trick for lazy susans. Its on the first page out in the "other bowling equipment " forum. Based on his idea, I came up with a spring loaded device the puts pressure on the check belt right in front of where the ball hits it. Very hard for the ball to roll back down once its adjusted right. In fact, if there are too many balls on the lazy susan, it will squeeze one out onto the approach.
The contraption is based on kicker paddle mousetrap.
Re: Lazy Susans.
Thank you all for the ideas, I will put them to use tom or the next day (not sure when I will have time, minor complications with the preg wife, not sure when I will be back to the part tiem gig) and keep you posted.
Re: Lazy Susans.
Paul I had 72 Lanes worth of those darn things in Louiville. the only thing that I did to make them work for the 6 Pounders was pull back the bottem end of the lesther strap away from the Wheele giving the ball more room to get to the wheele. This is a test to tell you if this will work or not. Get you a 6 Pound ball and sit it next to a 16 pound ball and throw a level across them The 6 pounder will be aboutn 1/8 taller. that is why i move the strap away so the 6 pounders don't have to move it so far.They say that the **** rolls down hill but the smell always starts at the top.
Re: Lazy Susans.
Not related to this type of ball return, but at my old house we had a problem with 6lb balls making it to the ball return fast enough (and as such getting stuck underground, at the base of the ball return).
The problem was only on one pair -- turned out that some of the clamps that secured the track to the floor at the end (near the downsweep) were loose or had completely fallen off. This caused the track to vibrate anytime a ball rode on it. It wasn't a problem for the heavier balls, but the vibration caused the 6-pounders to slow down just enough to cause them to not make it all the way. Secured the track back down, and they made it.
