Need Help w/ Twelve X Scoring!!
  • Need Help w/ Twelve X Scoring!!
    Kinda new at this scoring system.Have no manuals yet,Here's my problem....1st ball cycle everything is fine except for after the 1st ball is thrown,the scoring system scores again before the machine has completed the first cycle & The score is wrong (2nd ball score). Hope somebody can help me w/ this.
    AMF? Ain't My Fault!
    Re: Need Help w/ Twelve X Scoring!!
    do you know what version?
    i know on the version i have from the main status screen i believe its F8 fro misc. functions, then F5 to edit the pedestal setup. i am still learning myself, same scoring system. ill try to go to my front desk pc and look it up for you b4 i go tonight.
    hope this helps,
    Jeremy
    just feeling my way out like a blind man at an orgy.
      there is another option as well, at your pedestal during open play you can go to option 8 then press 9, then you need to know your password. in this screen you can set timeout for scoring to take a picture after trigger from ball sensor i.e. how long to wait after sweep drops.
      Just re-read your post, do you have i.r. ball sensor?
        I Have "Bowl-Tronics". Time-out for scoring To Take a Picture? How do you make the adjustment for that? I Know how to Do the pin-allignment(Figured that out myself),What controls The picture to be taken,& How do i make that adj.?
        Preciate all your help,Jeremy.
          If you bought them from 12 strike just give them a call they have 24-7 tech support. the phone #is 18004663695. good luck. if not wright back and I will check my books.
          curt
            Figured it out,Thanks guy's for all your help.
