any ideas??????????/
wierd
Re: wierd
First check to make sure the shuttle tubes are straight and has the correct gap between the pin holders. Obviously, also check to see if any tubes are broken. Make sure the 5 pin holders are not sticky, as to where this may pull that pin forward when the shuttle moves forward not allowing it to fall through. Check to see that the pin lays all the way back in the bin like it should, sometimes if the bin bumpers at the head of the pin get sticky they can keep the pin sitting too far forward in the bin and not allow it to fall through sometimes.
Re: wierd
Snobowl take your shuttle rod off and shorten it a turn or two this will pull the shuttle forward a little more and let that pin drop into the cups. Also as stated abouve make sure every thing is clean and tight.They say that the **** rolls down hill but the smell always starts at the top.
Re: wierd
I'd just put a bin strap on the 5 pin and see if it works. And then possibly shorten the shuttle rod 1 turn for a tad more forward clearance.
At our center, we run bin straps on everything but the headpin.
Re: wierd
Bin straps everywhere. Cheap protection....really helps to keep bin straight, rigid and unbrokenGo Pirates
Re: wierd
on the subject of shuttle straps, check that one isnt impeding the 5 pins journey to the spotting cupWant your old pins collecting anywhere in the UK? email me on jezsmith@aol.com
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
