Problem: I have a MP Chassis on an 82/70 Rev. C machine that when you turn the machine on you get nothing "Black out". So I hit the Chassis with a Pin Fork, Bam! Power, so it runs Scores Etc Correctly then when the Games over, Shutdown is Normal, now when you reissue the Said lane, Same Deal You have to Whack it with a Pin Fork (or Other Object Foot, pin, Wrench whatever)
... So I’m looking for Ideas, Comments and Such on what you did to Fix Said Problem
I have an Answer; I’m just curious what the others have done…
Just to state the obvious, it's probably going to be a sticking contact in a relay, or a bad solder joint / broken wire (open circuit) somewhere in the chassis.
Checking the connectors leading to the chassis would be the first logical move.
Swapping the board (and cleaning the connector) to see if the problem moves (to isolate it to the board or the chassis itself) would be the second logical move.
Not knowing much about the MP, I would probably start looking at the cardedge connector first, then work outward across the mother board to see if there are any broken / cold solder joints that may have cracked.
If the problem moves with the board, follow the above procedure above on the card to see if there's anything loose... not highly likely, but it's worth a look anyway.
Did you check the socket that M relay plugs into. If it is not the problem I would again check for somthing in the c1 c2 plgs as to somthing not making a good connection. When you Hit this with a pin do you see any sparks like somthing is loose or a a stuck relay. if not can you do it in the dark and see if you see anything light up when this happens.
And if that T4 tranny was not outputing high engough voltage, I guess it could be not quite enough to pull the relays on without a 'kick'. Nice theory Wang.
Does the chassis also start on impact of a bowlingball ? That way the bowlers can turn on the lane themselves, quite handy ! [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Alot of Good Ideas, but the Winner was AC Lines H, AA, KK were the Cause. Changed the Pins and Thats all she Wrote... No more Stress Release at least on this Machine
