What do you guys think about putting a grease fitting on the pinion gear? I know a "mechanic" who just installed them across the house. Problems with grease and bronze?
Grease Fitting on the Pinion Gear?
Re: Grease Fitting on the Pinion Gear?
One thing that helps the pinion is to drill out the oil hole a little larger before you install it.
This way you can get an extra drop of oil in the pinion."Gun control is the policy of tyrants"
Rep. Rob Bishop (R-UT)
Amen to using Enviro bushings in the pinion gear. I've had some in for FIVE years now and they are still running great. I also use a Enviro bushing split stop blade on all my dist. too. Sometimes you have to beef up the blade, but it's well worth it. With Enviros in the pinion and the stop blade no lubrication and NO MAINTENANCE at all. Some machines running 5 years without pulling a clutch apart. Well worth what they cost.
AMF DOCTOR
The doctor makes house calls.
We use enviro's, but I still add some lite oil to them (old school i guess, I like as little friction in my pinion/sleeve as possible.)
Greese is a bad idea. Greese + brass bushings = glue. They are called oillite bushings becuse they need a very light (straight 10 is what I prefer) oil. You greese them up, they will seeze over time.
Perhaps I was taught badly, but we've always used grease, not oil inside the pinion. I can see your point that oil is appropriate for a brass/oilite bushing, though, and I recall that the manual specifies oil (and generally I don't like to argue with a manual). But four head techs have done it that way, and four head techs trumps a manual (unless jacks are high or something [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] ).
I assume the reason grease is seen to be bad is that it would 'melt' under the heat and leak away (and no more lubricant = seizure).
We use high-temp bearing grease (HTB), but not sure what exact type. I'll check tomorrow.
The upshot is that it doesn't seem to melt and escape. Also, even if the grease did melt, would it not then be bascially the same as oil anyway? Doesn't the oil leak away?
How often should you re-oil the pinion? We overhaul each clutch perhaps once a year.
Andrew.
Original oil hole is not used. A new one is drilled and a fitting was inserted. He did this across 80 lanes. No special grease is being used either. He is using regular bearing grease. Does'nt it seem like alot of work to install, and to keep up with because of the constant greasing. Why not just install an envirobushing instead?
I use a imitation of Enviro Bushings works great.
<a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank"><a href="http://www.peet-peet.nl" target="_blank">http://www.peet-peet.nl</a></a></a></a></a></a></a></a></a></a>
I still use the brass bushings and they will never see grease as a matter of fact not too much of anything on my machines sees greese...I like to use light oil instead of grease, over time grease just becomes a big glob of a mess.Lifes to short to stress on little things.
Andrew.Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.
I too am an enviro man. however, i dont care for the enviro stop blades, too each their own. and i agree with Jim Dorsin, grease in pinions just turns into glue. before enivro's i was a drop of 10W-30 right on the pinion flange kinda guy.
