90XL Interlocks
  • 90XL Interlocks
    Does anyone know what inside the 90 XL chassis causes the sweep to coast and cause interlocks? Our warrentee will be up this summer so I'll want to fix what I can in the chassis's rather than sending them out. Any info is greatly appreciated. Thanks, Bill
    There! Try to NOT work now!
    Re: 90XL Interlocks
    Bill,
    The stop motor circuits are not unlike the old contacts in the original 70 chassis. It's a solid state relay now though. Remember, the sweep has to run in reverse with the new scoring now - so it should coast at stop in either direction.
    For starters, swap the sweep and table relays since the table is much less an issue if it coasts.
      Re: 90XL Interlocks
      Yes Ted, the relay in the chassis fails and has to be replaced.You try to adjust the sweep stopping position to counteract it, but it just creeps more until it is replaced.Interlocks occur and cams adjusted as a quick temporary fix.
      maister
        Re: 90XL Interlocks
        Hey Ted, I tried swapping the table and sweep relays the first time it happened a few months ago on a diferent chassis and it didn't change a thing. Sweep still coasted and the table didn't. Is that the only thing that will cause motor coasting? Anyone else have any other ideas? Thanks, b
          Re: 90XL Interlocks
          hi my firend, not forget check the OS swich (back the clevis )
          some times it not take adjustment and go to interlock.
          jesus from mexico
            Re: 90XL Interlocks
            Bill,
            I’m not real familiar with the 90’s…but from what I’ve read here, the breaking system on the motors requires a lot of maintenance or they fail prematurely. Try to see if the problem moves by swapping motors.
            Capacitors will also cause coasting. If you notice any hesitation when the motor starts, then that is a good sign you have a cap going out. A capacitor can also be going out but might not show the hesitation at startup which makes it more difficult to determine that it is the culprit.
            Triac
              Re: 90XL Interlocks
              AMF is aware of this problem stay on them to fix
              it right and keep up with the serial numbers and
              date's of the repairs dont put it on the shelf
              when you get it back put it on an run it remember
              the warranty starts the day you receive it
                Re: 90XL Interlocks
                we have the old 82/90 chassis,and have had to change a lot of the solid state relays recently because of this problem,works fine with new relays.
                  Re: 90XL Interlocks
                  I service an 82-90 center with 2nd generation chassis. Lane 8 was giving interlocks and continued to get worse even after adjusting the SC switch. So we decided to switch chassis with lanes 5&6. After switching chassis I cycled lane 6 and was looking for a coasting sweep and much to my surprise the sweep stopped about 6 inches off the pin deck. Go to lane 5 and the same thing happens. Both machines run through the rest of the cycle and stop at 270 and o degrees OK. Move over to 7 and 8 and both machines are coasting. Took about 20 minutes of fine tuning of switches and cams to get things running properly. Anyone with a reason why 5&6 would stop short of the pindeck? Im just baffled.
                  Paul -------That blew the bad relay theory
